Which oil would you run?
I'm running Redline 20w-50 in my car because I got it for half off, but I'm going to switch to Mobil 1 15w-50 or possibly a 40 grade oil since the mains in my LS7 have about 0.0027" clearance. I also have a Katech red LS9 (high volume) pump in my car, I kind of wish I had gone with the blue LS7 pump because I'm betting it's eating up more horsepower than it really needs to.
And I agree with you about Lucas. Pretty much any oil in the appropriate viscosity from Mobil 1, Pennzoil, Valvoline etc would be better I think.
My car no longer has an oil cooler on it, so the oil temperature is usually in the low 200s, I've seen it get as high as 245 when I'm beating on it. According to Driven Racing Oil, with a 0.0027" clearance on the mains for an aluminum block, a 40 or 50 grade oil is best.
I'm not terribly worried about cold oil flow as the car is rarely driven in sub 60 degree weather. And in the video below, 20w-50 showed less wear than 5w-20 on both startup, and after dyno pulls. After digging around in my engine after running 20w-50, I can tell you for certain that it sticks to engine components much better than the thinner oils, which is probably why it showed less wear in this test. It's also worth noting that as the oil temperature went up, the power loss from the thicker oil was dropped to about 5 hp.
If I put an oil cooler back on my car, I would certainly run a 40 grade or maybe a 30 grade. But when my car had the stock oil cooler on it, I would have to rip on it to get the oil above 160 degrees, and it would take 20 minutes of driving. In the spring and fall, it would often only get up to 140 degrees or less on my commute to work. Without the oil cooler on it, it warms up much faster, and the oil temperature usually levels out around 200-215 degrees depending on ambient temps, which is where I want a semi-daily street car to get so it can boil off any moisture in the oil.
Don't take this the wrong way, I do have a lot of respect for you, but I think a the optimal choice for my application is somewhere between a thick 40 grade and a thin 50 grade. I ended up going with a 50 grade because when I take a quick trip to Mexico, it often gets above 220.
I wholeheartedly agree. Lake Speed Jr's online content is actually what led me to choosing 50 grade oil for my car. The video I posted was from his YouTube channel, and the chart I posted was from Driven Racing, which they published while he was working for them.
SAE 20 grades are 5.6 - 9.29 cSt
SAE 30 grades are 9.3 - 12.49 cSt
SAE 40 grades are 12.5 - 16.29 cSt
SAE 50 grades are 16.3 - 21.89 cSt
So Mobil 1 0w40 is known for not being very shear stable, so it will commonly shear down into a 30 grade oil after a few thousand miles. That doesn't mean it's bad, it's just something that may be worth considering. I've run that stuff in my Jetta for the last 14 years and 130,000 miles. At 210,000 miles, it barely burns a drop of oil between changes, and the original turbo, which has not had an easy life, seems to be perfectly happy, even at double the amount of boost VW originally programmed it to run at.
If I understand correctly, the closer the "winter" (first number) rating is to the SAE grade, the more shear stable it tends to be. So a 10w40 is typically more shear stable than a 0w40.
I think you're mostly correct about the "winter" rating, but remember more flow doesn't necessarily always mean better protection. In the video I posted above, the 20w50 showed less wear metals from cold cranking than the 5w20 did. But I wouldn't be surprised if the 5w20 would have outperformed the 20w50 if they were conducting the test at below freezing ambient temperatures.
Most of what I know is from being a dork and watching a ton of Lake Speed Jr's videos. I'm not going to claim to be an expert, but I am pretty confident that what I'm saying is pretty accurate. If only Mr. Polyalphaolefin was still active on this forum so he could weigh in.
Plus the API rated oil for diesels is different than the SP rating for gasoline engines. But everyone can use whatever they want.
API oil rating chart for diesel and gasoline engines:
https://www.api.org/products-and-ser...l-c-categories
