5.3 swap Camaro
Old Jan 20, 2026 | 02:46 PM
Z28maro99's Avatar
Default 5.3 swap Camaro
So I’m installing a 5.3 on a 99 Camaro and I know I need the accessories and intake and fuel system and bottom end from the original motor but do I need to do a DOD? If so do I need to replace my cam if I’m doing a DOD? Do I also need to do a VVT delete? Do I need to change the cam whatsoever for anything? I don’t plan on adding performance cam.
Old Jan 20, 2026 | 03:14 PM
Bbknucks's Avatar
You dont have to do any of those.
If you change out the dod lifters to standard lifters then you will need to change cam to non dod
Old Jan 20, 2026 | 03:15 PM
LS1 TJ's Avatar
What year is the 5.3? What engine was in the 99? V6 or LS1? What trans in the Camaro?
Need much more info to be able to help.
Old Jan 20, 2026 | 04:23 PM
Z28maro99's Avatar
the 5.3 is from 2003 and the Camaro was originally a ls1
Old Jan 20, 2026 | 04:32 PM
RB04Av's Avatar
03 didn't have DOD. No need to worry about it.
Old Jan 29, 2026 | 08:02 PM
the_merv's Avatar
Veteran: Air Force
2003 5.3l is a direct install just drill out the drivers side ear on the front of Block and tap it Metric M10x1.5 so you can bolt up the Alternator Bracket.
