Do-it-yourself rebuild guide?
Old Mar 24, 2003 | 02:35 PM
LS1x2's Avatar
Formerly 4mulaJoe
Default Do-it-yourself rebuild guide?
Is there any place online where I could read up on how to rebuild the bottom end of an ls1? I'm just talking about rebuilding a 346 with some better pistons/rods in the garage.
Old Mar 24, 2003 | 06:55 PM
2000SSNB's Avatar
Default Re: Do-it-yourself rebuild guide?
ttt
Old Mar 24, 2003 | 08:49 PM
FastBlackTA's Avatar
ttt
you know, ive been wondering the same thing for a while. ive gotten some information off the gm service website at the dealership i used to work at, but thats about it. it's pretty helpful.
im building a 427 ls1 and i think it would be nice to have another source of info for the buildup, just for peice of mind.
Old Mar 24, 2003 | 10:11 PM
theblur98ss's Avatar
www.projecttransam.com
Old Mar 24, 2003 | 11:02 PM
Vents's Avatar
Jmx has some great info on www.LS1howto.com as in all the torquespecs and such. i just did one last weekend and it is seriously a piece of cake. just take you're time and do it right. corner cutting is not wise in building engines. much less ones that see use every day.
Old Mar 24, 2003 | 11:24 PM
Y2K2LS1's Avatar
I didnt see any LS1 rebuild guides on that page only LT1.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 25, 2003 | 06:37 AM
2000SSNB's Avatar
So, can the engine rebuild, installing a Lunati
382 stroker kit or similar, done without the engine out of the car - on a lift from below?
Thanks,
Gert
Old Mar 25, 2003 | 07:38 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
No, installing a stroker cannot be done "in frame" (in the car). First off the cylinders will need to be bored or honed (depending on the ammount of overbore) for the new pistons. Also, it is critical to check the clearances of the crank and the new bearings. And, when doing a motor you need to make sure everything is super clean. I just saw a destroyed 382 that the guy tried to do himself. Very little was salvagable after it came back out from improper assembly and not keeping it clean.
<small>[ March 25, 2003, 07:39 AM: Message edited by: J-Rod ]</small>
Old Mar 25, 2003 | 08:02 AM
Black Sunshine/ 00SS's Avatar
GM makes a book, it's in the Performance Parts catalog, It's 88959384-LS1 Engine Kit Installation Guide. I dont know what the price is, or how usefull it would be.
