2001 LS6 Block??
Old Jul 30, 2004 | 08:45 PM
PewterNHRA2001's Avatar
Default 2001 LS6 Block??
I read something that said that some 2001 and 2002 trans ams had an LS6 Block in them? is this true and how how would i know if i have one? also the intake manifold on the 2001 is the LS6, right?
Old Jul 30, 2004 | 10:11 PM
FASTONE's Avatar
Yes on the ls6 intake and I think the block will have a number on the front near the heads????Maybe someone will help?LS 6 block is not really better then ls1 little better internal breathing.
Old Jul 30, 2004 | 11:07 PM
what # am i looking for to be able to tell if its an ls1 or ls6??
Old Jul 30, 2004 | 11:16 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
12561168 is the LS6 block.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Aug 8, 2004 | 03:14 PM
jrtf83's Avatar
Post
http://www.fbody.com/cgi-bin/ls1/read.cgi?msgid=38022
Originally Posted by my1973form
Yes there is, on the driver’s side under the hood you will need to use a mirror to check the block ID which is located just below the head on the block deck, above the transmission flange. A cast-in 12651168 denotes a LS6 block. There is another way but not too sure how accurate it is but there is a bulls eye located on the block on the passenger side just below the head if you have this I believe it’s a LS1 block if no bulls eye it's a LS6 block. Also the luster of the block is shinier if it is the LS1 and if dull (like sand blasted aluminum) it’s a LS6 block hope this helps.
