Who in your opinion makes a better custom cam..
Old Aug 4, 2004 | 10:43 PM
MakoLS1's Avatar
Default Who in your opinion makes a better custom cam..
Im looking to get a cam, a custom grind most likely for my ported and polished stage 2 heads. I can do a cam swap in 2 hours. But when it comes to decideing what matches what i dont understand. So my game plan is to call these 3 places, give them my exact mods and head specs and see what the tech says from each place, talk **** and compare. I only hope i get a good tech that knows LS1s from each place. Have any of you have any experience with custom cams from these places? Any info will be VERY helpful.
1)Lunati
2)Comp
3)Crane
Old Aug 4, 2004 | 11:11 PM
MUSTANGEATER's Avatar
1)Lunati
2)Comp
3)Crane
I think you'll find yourself more succesful in getting a good camshaft grind when calling someone who designs custom camshafts as a living as opposed to the cam company themselves.
Email Bret Bauer @ Bauer Racing he's a sponsor --------------------->
Old Aug 4, 2004 | 11:13 PM
98_1LE's Avatar
I think they all make good cams, and a lot of variations that are close but not the same. Options are good. I think the Comp XE-R cams are about top power makers. I have the Lunati 231/237 cam. The slower ramp rates are easier on springs than the similar sized G5X2, although the X2 makes more power and torque.
Old Aug 4, 2004 | 11:15 PM
Ben R's Avatar
I know he's not a sponsor, but Ed Curtis is well-known in the automotive community for specing some wicked custom camshafts. You can get his contact info at www.flowtechinduction.com
Old Aug 4, 2004 | 11:29 PM
MakoLS1's Avatar
I dont see ed curtis name anywhere on the site, muchless contact info. Is that his company or something? If so, when i call the tech line i dnt see it any different then Crane, Comp, or Lunati advice.
Old Aug 4, 2004 | 11:37 PM
Email ED he's very good too. His board name is EDC. Chris straub is good too, his board name is Cstraub.
Old Aug 4, 2004 | 11:41 PM
Ben R's Avatar
Ed's username on this website is 'EDC'. Flowtech Inductions is partly his company. I believe it was a joint venture between him and some of his collegues.
What do you meant about the Tech Line? I'm a little confused.
Old Aug 4, 2004 | 11:45 PM
Unaffliated Racing's Avatar
I think Comp has done a great job designing custom cams for a living. I don't know how all those cam profiles got into their catalog, but I guess since that they are part numbers they have been proven time and time again. If people could look past the duration,lift, and lobe sep..they would have a different point of view on " custom " cams.
Old Aug 4, 2004 | 11:49 PM
MakoLS1's Avatar
nevermind that last reply, i found his email address on that site. But it dosent even work.
Old Aug 4, 2004 | 11:51 PM
Ben R's Avatar
Don't you work for Comp Cams?
Old Aug 5, 2004 | 12:14 AM
Well when you call comp and get the normal jack off catalog internet racer that you would find on here let me know how far that gets you.....
It'd be best if you call comp and ask for Scooter, he should be able to help you. LOL!
Old Aug 5, 2004 | 12:15 AM
Oh yes I forgot to include the people who have been listed in this post thus this far are capable of making their own lobe design, there's a lot more to a camshaft than that but I don't feel like going into it.
Old Aug 5, 2004 | 12:26 AM
BTW
This isn't a rip on Comp or you at all they make a good product, hell I use them. I was just stating you never know who will pick up a phone when you call someplace! When you call someone who does nothing but custom camshafts especially for a certain style of racing and is known for building things for racers that's the best bet IMHO.
Old Aug 5, 2004 | 10:10 AM
99C5JA's Avatar
I've been considering contacting Futral Motorsports to see if they'd be able to build me a custom cam based on my heads. They seem to make great cams.
Old Aug 5, 2004 | 11:01 AM
cyphur's Avatar
Call Texas Speed or Futural and see what they can do for you. They both have some wicked cams out there. They both run LS1 platforms for a living. Thats what they do. Obviously they know their **** concerning camshafts, otherwise they wouldn't sell the hundreds of cams that they do. Both are sponsers --->>>>
Old Aug 5, 2004 | 11:08 AM
BLKWS6's Avatar
Old Aug 5, 2004 | 12:04 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
I know guys at Comp. This is not to knock them. When you call , the guy is most likely going to sell you a box cam. You're not going to get a custom cam from some first line guy making $9/ hr answering a phone. When you want a custom cam designed, here are some of the things you will need. If you don't have this info, before moving forward and wasting both your time and your cam designers time get the info they will need.
The biggest deal is cylinder head flow (with the intake in place preferably) - No cam shaft designer cares that you have "Stage XVII super duper flow heads" that means 0. They only care about the runner volume and the flow. This helps determine you cam "budget".
Here is an example of a custom cam designer worksheet. If you can't fill in this information, then no one can provide you with a truly custom cam. Depending on designer, they may need even more info, but this is a good baseline.
Year, make, model, and weight of car:
__________________________________________________
Engine type: SOHC , DOHC , PUSHROD
Rocker arm type and ratio
(if applicable):______________________________________ ____
What type of lifters are you going to use? (circle one on each line)
HYDRAULIC ROLLER TAPPET
SOLID ROLLER TAPPET
What is the diameter of the lifter? (ex. .875")___________________________
Engine size:_________________Compression ratio:___________________
Bore:_______________________
Stroke:______________________
Connecting rod length:_______________________________________
(center to center distance)
What has been done to the heads?
Ported? _____________________________________________
Valve sizes: __________________________________________
Springs you intend to use: _______________________________
Flow tested? If yes, what are the flow figures at .050" intervals:
Lift Intake CFM Exhaust CFM
.050 __________ ___________
.100 __________ ___________
.150 __________ ___________
.200 __________ ___________
.250 __________ ___________
.300 __________ ___________
.350 __________ ___________
.400 __________ ___________
.450 __________ ___________
.500 __________ ___________
.550 __________ ___________
.600 __________ ___________
.650 __________ ___________
TEST PRESSURE @ _______" H20
Transmission type: STANDARD OR AUTOMATIC
Transmission ratios:
1st ____
2nd ____
3rd ____
4th ____
5th ____
6th ____
Is idle important to you?_____________________________________
Description of intake system:_________________________________
Description of exhaust system:________________________________
DIAMETER=_____________LENGTH=_____________________
How is the car going to be driven?_____________________________
What type of fuel will you be using?_____________________________
As mentioned, some of the sponsors and non-sponsors make can generate you a custom cam for your particular combo. One thing to realize is that when you make changes to that combo, in theory at least a cam change may be in order (if you change headers, or intake, etc...) Most folks won't. My point is, get your "package" all together (everything you want to do), then order a cam.
If you want a truly custom cam the main thing is to not waste a custom cam guys time. He doesn't have time to evaluate you list of free mods to your car, and spend an hour on the phone with everyone playing 20 questions.
These guy are in demand, and their time is not something they can give away for free. Also, don't call one of these guys and expect him to give you specs over the phone for a cam that you can "evaluate" i.e. not pay them, and save a few bucks by ordering what you think they just told you from Comp. Even if they do give you the specs @ .050 chances are they aren't just using an off the shelf XE or XE-R lobe. As an example, Ed has 50 lobes which spec out at 224 @ .050 but have all sort of different lifts @ .200 and up , plus differnet lifts...
The other thing is that the cam you get may not be what you are used to seeing
i.e. Comp 224 lobe /comp 224 lobe 114 LSA - 110 ICL
Some of these guys do thing "outside the accepted norm" the results are what matters. So if you are willing to do something different then you might want to try a cam from a custom cam desinger.
To quote Ed Curtis:
All questions are a PITA... :-)
It's the Ben Franklins that get results...
Old Aug 5, 2004 | 12:12 PM
Ben R's Avatar
Great post J-Rod.
CHRISPY's Avatar
I think rear axle gear (final drive ratio) should be included there as well.
That sheet looks great
Old Aug 5, 2004 | 12:35 PM
pman's Avatar
LSM Motorsports hands down!!! They produced the cams for the
C5R race program and do many development projects for GM. 248-674-4967. Tell them Paul from "The Shop" sent you
