Large cam
Old Aug 7, 2004 | 12:43 PM
JZ'sTA's Avatar
Default Large cam
I have a set of stage 2.5 6.0 L AS heads on the way to go onto of my built 347 LS1. Fast 90mm TB and intake, 1 3/4 stepped tp 1 7/8 LT's, and all the bolton's.
I have almost all the suspension on the car you can do, with 26x10x15 MT ET Drags, and a Brand new Yank 4200 conerter.
The car is driven on the streets in Fl where we have no emmision's, but not driven too much. Probally 50-100 miles per week.
I am trying to run 10.7's with the above setup in a full weight 98 TA. \
However I dont want this car to be a race car only, which is where I need a little help.
Cam ordered by Jay was a 234/238 598/605 112+4.
Again I have a A4.
I drove up to tampa a few days ago and heard a F body M6 with a 230/236 575/575 (somewhere in that area in lift) on a 112.
The car sounded radical and it's in a M6 tuned by the same guys I use for tuning. I have a bigger cam and a A4 and dont think I would enjoy my car the way I would like if the cam is too lumpy.
I am thinking about ordering a new cam. What wopuld be the negatie of ordering something with way more timing ground in to the car?
Most cams are on a +2 or +4 which helps keep the power in a more usable area and the peek not so high.
What is wrong with +6 or +8?
Why do I see almost no cams ground with this much advance?
I have been considering staying with the same duration and lift but changing the LSA to a 115+8.
This would make the car more street friendly without having to shift at 7400 RPM's. Anyone tried this or can help me out on this subject?
Thanks
Old Aug 7, 2004 | 03:49 PM
JZ'sTA's Avatar
TTT please
Old Aug 7, 2004 | 06:14 PM
JZ'sTA's Avatar
No one has tried this or has any info?
Really need some help.
If you need any more info let me know and I will gladly post it.
