Started my cam install!!! got a question
Glad to hear you are making progress. I too was a little worried about your situation when you came in asking where the starter is and what does it look like. But, it sounds like you are catching on fast. Good luck. BTW, Boston is having a concert?? I didn't know they were together anymore. That outta be a blast to see and hear. I was a huge fan years ago and still crank them up from time to time.
the larry tool helps a lot and is really easy to use, and i thought the air compressor hose thing was easy to use, i took a compression tester, and removed the schradder valve from the hose so that it would blow air through, this little short hose worked great cuz you could turn the end of the hose and it would screw it in.
pretty big install for your first time working on a car. good job
Hang in there man, it will all be worth it in the end.
Sorry man, I just cracked up so ****** hard when I read these lines that my face started to hurt. I don't think I ever cursed on anything as much as I did to that damn pick-up tube bolt. Make sure its seated right though or you'll have to tear it back down if you have low or zero oil pressure.
I was referring to being careful about routing the KS wire when reinstalling the intake.
and for anyone that is planning on changing their cam, a 5/16" metal rod works like a charm to keep the lifters from falling.
