How much power can the LS1 handle?
Thanks Sean
(not trying to talk $hit but pretty brave for a first post)
For instance, take 400 ft/lb... a figure that is fairly easily achievable on a heads/cam stock short block LS1:
1) For this example, let's say that you make that 400 ft/lb at, say, 4500 RPM. Since HP = (TQ * RPM)/5252, we see that 400 ft/lb at 4500 RPM equals 342 HP.
2) For this example, let's say that that same 400 ft/lb occurs at 6500 RPM... the result is 495 HP.
Just remember that V8's don't have to be turned that tight (8000+ RPM) in order to make power... especially when force-fed. Massive amounts of torque at lower RPM may not impress your friends at the dyno with a stupendous HP number, but you'll leave 'em in the dust when it comes time to lay the hammer down on the road.
FYI, you may want to check this out: https://www.quartermileperformance.c...ormulation.asp
i havent come across any with that much yet, hmm
This thread seems a little trollish.
Any of the Honda series of engines have very good flowing heads for their displacement. Add a MID sleeved block, turbo, tuning, the usual hop up parts, good intercooler and you have 500 reliable street horsepower from the H series 2.2 liter engines. This with the stock two bolt caps and bolts on the block. In fact the little Honda B series race engine below used the stock factory caps, bolts, and crankshaft.
The attached graph is from a friend's race car running methanol on 25 lbs. boost. This is a 1600 cc engine (B16A), 97 cubic inches. This dyno run was in Denver by the way. Peak wheel torque 574 ft./ lbs. @ right around 6,500 rpm. Power was still increasing when they stopped the pull, 775 HP @ 8,300 rpm.
I should point out that this engine was no world beater, basically stock heads. I know another fellow that pulled just about 1,000 HP out of his 1600 Honda. You can make a lot of power with 35 - 40 lbs of boost.
The Ford Cobra has been built to right around 1,700 HP on methanol and turbo. Bottom end on that block, the whole block in fact, is a joke compared to the LS1 block. An LS1 properly built and tuned should exceed that number by a good margin.
Steve Demirjian
Race Engine Development
When was the last time you got a Challenge from a 500 hp Honda from a dig?/
That's because by the time they get to "boost levels" we are 3 car lengths ahead and the race is over.
I quote from a fellow member:
"I shall fear no evil while I walk through the valley of rice, for torque art with me"
I love this idea that the ricers have that they can make 500 or, the more common, 750 hp "easily" with a 4 banger. Ya sure they can put out 500+ Hp with 40lbs of boost of a 250 shot of NAWS for like a month and then the engine kicks the bucket.
Torque rules period.
With an LS1 in a little RX7, you'll be able to use the nice tall factory gearing since there's so much torque and as the 500 hp honda your racing is shifting into 3rd gear at 50 mph and running out of steam, you'll be just getting into 2nd and pulling like a ****.
honda... wiiiing [20 MPH
] wiiing [55 MPH
] waaaaaaaa....LS1... ROOOOOOOOOOOOOOOOOOOAAAAAAAAAARRRRRRRR [50 MPH
] ROOOOOOOARRRRRRR.....
I've seen a couple honda's do some pretty amazing things. There's a couple here in Houston that are especially crazy. I'm talking about street Hondas trapping at 130+. That's impressive for a 4 cylinder car. Cheesefrog (Local Honda Hero) says the goal for his new setup is to trap 150 MPH in a full interior street car. Wonder if he'll make that...
