Enough room for ARP head studs?
Old Aug 11, 2004 | 10:40 PM
jermstyle's Avatar
Default Enough room for ARP head studs?
I’m looking into probably getting the hex ARP head stud kit for my up-coming head swap. Are there any clearance issues getting the heads over the studs? If so, I’ll just go with the ARP bolts or even stockers…
Thanks!
Old Aug 11, 2004 | 10:49 PM
Jason99T/A's Avatar
I can shift faster than you.
There is plenty room to do a head swap in the car with ARP head studs. Much easier than the GM torque-to-yield bolts, in my opinion.
Jason
Old Aug 11, 2004 | 10:50 PM
v8maro's Avatar
I was told you can take out the pass side thru bolt on the motor mount and lift the motor a tad if you need the clearance.
Old Aug 11, 2004 | 11:02 PM
jermstyle's Avatar
Nice… I’ll probably go with the studs then, I’m trying to use studs where ever I can.
The header studs just aren’t practical with the LS1 though. I’d pay to see someone get my 1-7/8 KooKs LT’s over studs that are pre-installed into the head.
Maybe if you put them in like a bolt and then put the nut on it would work, still a pain though.
Old Aug 11, 2004 | 11:05 PM
Jason99T/A's Avatar
Save your money on the header studs. lol
Old Aug 11, 2004 | 11:21 PM
cyphur's Avatar
there's better places to throw your money at
Old Aug 11, 2004 | 11:31 PM
jermstyle's Avatar
Yea... I just used the stock header bolts with some lock tight.
Anyone thats interested in making a deal on some hex head studs, PM me!
