Oil Leak Questions
If you have to change it without the tool, you'll have to remove the pulley, water pump, and timing cover... then use a screwdriver to pry the front seal off of the timing cover, pop a new one in, then reassemble.
Either way, make sure to get a new crank bolt because you can't reuse the one on your car.
Now, if you're referring to the crank seal then yes, just remove the pulley, use a seal puller to remove the old seal, seal driver to install new seal, install pulley.
