Engine tapping at idle
Old Aug 12, 2004 | 05:15 PM
Need2gofaster's Avatar
Default Engine tapping at idle
When at an idle, my ss will make a tapping sound almost like a pushrod noise. if you give it any rpms it goes away. I know that these LS1's have a oil pump problem, could this be the case? Also, it dosnt make this nosie all of the time. I'm stumped! The car only has 22,000 miles on it. Any help?
Old Aug 12, 2004 | 09:14 PM
Raise's Avatar
the ls1 has noisy injectors...could be lifters too. theres a post somewhere about all the normal valvetrain noises u should hear.
Old Aug 12, 2004 | 10:00 PM
gasalene's Avatar
Oil pump "problem"? Hmmm.... What is this?
The tapping you hear @ idle...might this be the PISTON SLAP problem the LS1s have from the factory (many posts on this topic ; search 'em out!)?
Also, in your search, look for my solution to the piston slap / needle bearing (on roller tappets) problem(s)...on replies to these posts. CIAO!
N.C. also...'98 Vette/M6
