Intake Manifold Porting?
Old Aug 17, 2004 | 02:30 AM
98 Z's Avatar
Thumbs up Intake Manifold Porting?
I tried to do some searching and came up with only very general information.
Basically what I was wondering is...
Can the inlet be opened up to around 80mm to accept a larger TB?
Obviously a high flow set of heads with a large cam would be prerequisite to a ported intake but once you have those, what are some typical gains of a ported LS6 style intake over an unported one?
Where does most of the material come off at... where the two ports meet? Similar to a port matching? Higher up in the runner?
Old Aug 17, 2004 | 03:27 AM
PREDATOR-Z's Avatar
Yes it can be done but requires cutting and rewelding of a new mouth piece.
Old Aug 17, 2004 | 02:26 PM
JDPZ28's Avatar
what about port matching where it meets the heads if you have ported heads?
