Does a cam need to be broken in?
Old Mar 27, 2003 | 09:46 PM
CRUZMISL's Avatar
Default Does a cam need to be broken in?
I want to swap my cam, pushrods and retainers but am unsure if it needs to be broken in after or can you just start tuning it on the dyno? Just curious.
Thanks,
Joe
Old Mar 27, 2003 | 09:59 PM
Brian98's Avatar
Default Re: Does a cam need to be broken in?
What about your springs.....depending on how agressive your cam will be you will need to change your springs. Most people r using 918's from comp cams they are a single spring set up. if you go with a dual spring you will need to have the seats worked....
You will need to break in the new cam/springs
go to ls1howto.com and follow jmx's procedure...its pretty simple <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 27, 2003 | 10:01 PM
Brian98's Avatar
Old Mar 28, 2003 | 06:40 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can, but I like the idea of putting the valve springs through a few heat cycles, it's not the cam you have to worry about it's the valvesprings.
Old Mar 28, 2003 | 07:53 PM
JBsC5's Avatar
Why not consider using the rev 1116 dual springs?
Joe, The weak link seems to be the valve springs some chose.
Old Mar 28, 2003 | 07:56 PM
CRUZMISL's Avatar
Oops. I plan on replacing the springs as well.
Any other advice? I'd imagine tuning on a dyno would be ok since I doubt most tuners put 500 miles on their customers cars before tuning.
Thanks,
Joe
