Will 6.0 heads fit on a ls1
Old Aug 24, 2004 | 06:18 PM
Y2kforgedSS's Avatar
Default Will 6.0 heads fit on a ls1
like the title said? i was wondering what power would the heads make on my car if they fit.
Old Aug 24, 2004 | 07:20 PM
Cheatin' Chad's Avatar
Yes they fit.
Use search feature for specifics
good luck
Old Aug 24, 2004 | 10:03 PM
i did and didnt get anything good from it.
Old Aug 24, 2004 | 10:25 PM
https://ls1tech.com/forums/showthrea...&highlight=LQ9
I wouldn't even be able to guess what kind of power you woudl gain from them.
I can tell you that as is they will drop compression compared to your 5.7l stock heads. Which can be a good thing with your FI set-up.
They do flow better than stock 5.7 castings. Which should provide more power.
More flow and lower CR which could allow you to run more boost should make a decent difference in power once you sort things out.
Old Aug 25, 2004 | 12:14 AM
Ok thanx man you helped me out.
