Any AFR vs. OEM pics?
Old Sep 1, 2004 | 12:36 AM
Grant B's Avatar
Default Any AFR vs. OEM pics?
Does anyone have pics (as detailed as possible) of the AFR combustion chamber and ports compared to the stock stuff? I'm curious to see the difference.
Old Sep 1, 2004 | 01:28 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
Default Pics...
If I can find the time to shoot and email them to you, will you be able to post them for me? I have a stock Z06 head and obviously the AFR is not a problem....
Old Sep 1, 2004 | 07:57 AM
jrp's Avatar
jrp
SN95 Director
do a search , KingKrabBox posted some very detailed pics not to long ago, the ports look great.
Old Sep 1, 2004 | 09:56 AM
Grant B's Avatar
Ah, found it. Thanks anyways Tony, but these will do.
AFR pics:
https://ls1tech.com/forums/generation-iii-internal-engine/203115-g-force-205cc-afr-head-flow-s-inside.html
LS6 head pics (although I'm sure someone has posted better pics):
https://ls1tech.com/forums/generation-iii-internal-engine/173999-pics-my-fms-stage-3-ported-ls6-5-7-heads.html
Sure looks like the AFR chamber size would be smaller with that extra little bump in the quench pad by the bottom Is there actually more valve clearance, or do my eyes deceive me?
