226/575/114 IN AN A4 WITH 3.23S?
Old Mar 30, 2003 | 10:50 PM
JaSSon's Avatar
Default 226/575/114 IN AN A4 WITH 3.23S?
WANT TO KNOW IF IT WILL WORK WITH THOSE GEARS AND CONVERTER IN SIG. IF YOUVE DONE IT WHAT WERE YOUR RESULTS,DID IT MAKE GOOD POWER? HOW DID IT IDLE? SORRY ABOUT THE CAPSLOCK.
<small>[ March 31, 2003, 06:26 AM: Message edited by: J2KSS ]</small>
Old Mar 31, 2003 | 06:28 AM
JaSSon's Avatar
Default Re: 226/575/114 IN AN A4 WITH 3.23S?
SOMEONES HAD TO HAVE DONE THIS. COME ON GUYS I NEED TO CAM UP.
Old Mar 31, 2003 | 08:49 AM
Mike Hoffpauir's Avatar
I run the cam from Futral with those same specs.
I ran the car with 3.42's and went soem 11.40's@118. the idle quality of that cam is great. The only thing is, 3.23's are too little gear for it for maximum 1/4 mile e.t.
To take full advantage of the cam you will need to put it in its powerband, which those 3.23's will not do in the 1/4 mile. Something like 3.73's would be good, and 4.10's ideal. But if you just want a cam and arent an all out racer the 3.23's will work, but the car will benefit from more gear.
Old Mar 31, 2003 | 04:05 PM
JaSSon's Avatar
hey mike thats the cam i want. gears are in my plans(4.10}. why kind of rpm would i go through the traps at? would i benefit from cam or gears now? iwant both but have to do one at time although the other would not be far behind. what are your rpms at 70mph mike?
<small>[ March 31, 2003, 04:07 PM: Message edited by: J2KSS ]</small>
Old Mar 31, 2003 | 04:21 PM
Cal's Avatar
Cal
I you hit the traps at 115 mph, you will be turning 6156 rpm in 4th gear on a M6. At 70 mph, you will be turning 1874 rpm in 6th gear.
Old Mar 31, 2003 | 04:23 PM
Cal's Avatar
Cal
Whoops never mind, I didn't notice you have a A4 . . . <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Mar 31, 2003 | 07:17 PM
J2KSS, what tires do you intend to run?
With 26 inch tall et drags, and 121 mph trap speed I was going through the traps at about 6500-6600 rpms. If you are on a short drag radial 4.10's will force you into 4th, which means 3.73's would be better. The difference between 3.73's and 4.10's should be 200-300 rpms through the traps.
With a standard size radial 80 mph is 3000 rpms.
Old Mar 31, 2003 | 07:27 PM
JaSSon's Avatar
hey mike i run 26"et drags. as for highway driving the standard size you are talking about are they factory size? i rue 15"draglites with 275/60/15s for daily driving what do you think the rpms at 70 to75 would be?btw thanks for info. <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
<small>[ March 31, 2003, 07:29 PM: Message edited by: J2KSS ]</small>
Old Mar 31, 2003 | 08:29 PM
2500 I think, but I'm unsure.
