Measuring lifter pre-load
Old Sep 7, 2004 | 09:48 AM
BenKey's Avatar
Default Measuring lifter pre-load
Sorry if this has been asked before.
I have read through many threads on determining the amount of pre-load with a gauge, but have yet to read what kind of gauge or where to purchase. Can someone direct me to a brand/type/place etc... to get one?
I am trying to track down some valvetrain noise and just shifted to Comp pro-magnum 1.75 rockers (cam lift .575/.576 w/1.7). It's noise above the normal sewing machine sound. This is tap. I installed them, adjusted for zero lash, then added 1/2 turn, then locked down the fastners. The noise changed, but didn't get much better. So I readjusted to 1/4 turn. Again the noise changed some, but still present. My next step will be to go to 1/8 turn, but without a gauge it will be a little hard to be precise. How much pre-load "should" I have?
At what point do I need to consider replacing the lifters? I just had my motor built and had new Melling lifters put in, but up until now, it still had the stock rocker. My motor has 400 miles on it.
Old Sep 7, 2004 | 09:56 AM
Hysteria's Avatar
You want .030" preload. Sometimes new lifters, or old lifters that have been out of use for sometime, will loose or not gain full prime. Take the adjustment to zero lash with no preload and lock it down and run the engine for about 15 minutes. Readjust to the 1/2 turn(.030") preload and that should get it.
Old Sep 7, 2004 | 10:22 AM
SAM98WS6's Avatar
NOT TRUE!! You want .008-.010 Preload with comp pro magnums (cold)
1/5th of a turn is just about perfect but using a dial indiactor will get it right on.
I called Comps tech line...have had no valvetrain issues..and others here that went .008-.010 had had no issues that I know all...guys with more preload have had issues.
Call Comps tech line if you have doubts between us.
Old Sep 7, 2004 | 10:38 AM
Hysteria's Avatar
.030 is max on the comps because they can be used like a solid, you can vary your preload for tuning purposes.
Old Sep 7, 2004 | 10:48 AM
BenKey's Avatar
You're not referring to CompR lifters are you? I know that is what they call for. What type of dial indicator and where can you get one?
Old Sep 7, 2004 | 11:54 AM
SAM98WS6's Avatar
I do have Comp Rs...missed your Melling.
Call the tech line and get the recommended answer for your lifter...you obviously want to run as little as possible with maximum reliability.
Any dial indicator with a probe and magnetic base. mount it at zero lash..tighten until the rocker pushes the recommended distance. Summit sells them...Harbor freight
Dont listen to any of us..you have melling lifters and comp rockers...how could we possibly have the right answer for you?
Old Sep 7, 2004 | 12:23 PM
BenKey's Avatar
Is that an unusual combo, or something?
Old Sep 7, 2004 | 12:53 PM
marc_w's Avatar
Ben, I don't have much of any info to help you... just wondering about that tapping noise. Is it one or two complaining lifters or rockers, or is it the 'whole set'?
I had an unusual intermittent valvetrain noise with my last cam. Stock lifters, stock rockers. It sounded like one, maybe two lifters tapping. I could hear the noise through the firewall when driving, echoing in parking garages or next to cement walls/barriers. It was 'quite' noticeable. Is this what you have?
Old Sep 7, 2004 | 01:22 PM
BenKey's Avatar
Very similar yes, but it's constant.
Old Sep 7, 2004 | 01:56 PM
marc_w's Avatar
Dang - I wish I knew what it was.
I drove around like that for quite some time, basically thinking it was rather normal valvetrain noise. It just about completely cleared up about two weeks ago, all on it's own.
The cam was still a little noisey - there was still a small amount of tapping only heard if you listen close outside the vehicle, but it wasn't anything that really raised a flag with me.
Old Sep 7, 2004 | 02:17 PM
BenKey's Avatar
I'm used to the "normal" noise that bigger cams, stiffer springs cause. This is not the sewing machine sound. Very annoying.
Old Sep 8, 2004 | 10:18 PM
Taphee6's Avatar
Default Valve Covers
Check the valve covers. With the Pro Mags I had to remove the rear baffle on the drivers rear valve cover. It is a little piece of sheet metal that just hits the rocker.
Old Sep 8, 2004 | 10:33 PM
LASTLS1's Avatar
6 Second Club Moderator
My exhaust is so loud now, all the noises blend together! With comp r's I set mine at .014, but I'm going to reset them to .002-.004. I think .014 is too much.
Old Sep 9, 2004 | 06:12 AM
BenKey's Avatar
I had some valve cover issues, but I fixed those when I installed them - thanks.
