Replacing Oil Pump in a C5
Old Sep 11, 2004 | 06:36 PM
LS1POWERHOUSE's Avatar
Default Replacing Oil Pump in a C5
Looking to replace a oil pump in my buddies 2000 C5 M6 car do I absolutly have to pull out the crossmember and suspend the engine???? or is there any other way????
Old Sep 11, 2004 | 06:47 PM
pdd's Avatar
pdd
nope just remove the sterring rack. pull off the crank pully and timing chain cover and your all set.
Old Sep 11, 2004 | 07:03 PM
what about disconnecting the pick up tube can you do that with the pan on?
Old Sep 11, 2004 | 07:21 PM
Scalpel's Avatar
Yes. The pickup tube bolt is in a much better position on the C5s. Very easy to do. No need to do anything to the oil pan bolts.
Old Sep 11, 2004 | 07:28 PM
worked on numerous ls1 camaro's is this about the same amount of work? How long of a job is this with tools ready to go?
