LS1 build opinions wanted
Old Sep 16, 2004 | 09:16 PM
YsoFast's Avatar
Question LS1 build opinions wanted
Guys the time has come to start building a 2002 LS1 with 8k on it. I would like to know what everyone thinks of my parts list because I had a few people questioning some of my parts. At this time I plan on stock rockers but that may change after hearing about the bearing getting spit out on a few cars. BTW This is the setup going in the IROC with custom LT headers and a 12 bolt.
Heads:
Absolute Speed 2.5 3.5L
Milled: ~.025
Springs: Comp 977 with Ti retainers
Valves: 2.04 and 1.575
Cam:
Futural Motorsports # FM-F13-14 SPECS 230/232 114+4
IN/EX Duration 229.8/232.2
LOBE SEPERATION 113.9
INTAKE CENTERLINE 109.5
Lifters:
Comp “R”s
Pushrods:
7.350” (Texas Speed)
Intake:
F.A.S.T. 90mm
Throttle Body:
F.A.S.T. 90mm
Injectors:
30lbs SVO red tops
Old Sep 16, 2004 | 09:20 PM
itchygomey98's Avatar
Ummm I don't know - is that gonna clear?
Old Sep 16, 2004 | 09:21 PM
jrp's Avatar
jrp
SN95 Director
have you confirmed that the FM13 will clear the 5.3's being milled .025?
Old Sep 16, 2004 | 09:23 PM
That's the only concern I would have. Oversized valves, milled .025, and a pretty healthy cam could mean BOOM.
Old Sep 17, 2004 | 07:54 AM
YsoFast's Avatar
The engine builder with look it over to see if cutting the pistons is needed if thats what you mean. On a 114+4 it should work but it will be close.
Old Sep 17, 2004 | 07:56 AM
That's exactly what we mean. Other than that, I don't see any reason why that would not make power.
