I lifted a head on the dyno......
1. Change to a different head gasket- you need to replace them anyway since one of them will be ruined.
2. Go through your entire fuel system. Check fuel pressure at WOT at torque peak.
Something seems amiss. Were you logging on the dyno runs?
If you only did it once then that is your issue probably.
What fuel were you using? Dry or wet shot? How much advance?
Details man!!
Ditto, what fuel octane, timing and AFR were you at?
I plan on running 104 URL whenever I spray, its just cheap insurance, and timing with a 200 shot will be around 18ish for my motor(10.7:1) and the AFR will be low low 11s, to start out with, I think I will be safe.
How much do you spray? Whats your total HP?
Sure you can spray a 100 shot with your combo...but I do not believe you could spray a 200 shot that way.
On my 383 I would get detonation around 600 rwhp on 93 octane and 27 degrees of timing.
Also...to the original poster...what rpm did the juice come on...what was your TQ? Many times for nitrous cars...its not the peak HP where the problem occurs...its at peak Tq...which is usually as soon as its activated. That where cylinder pressure is greatest.
, NGK V-power #8 plugs, etc.
