918's with an XER cam??
Old Sep 17, 2004 | 01:00 AM
Zach@Texas-Speed's Avatar
Default 918's with an XER cam??
are 918's sufficient with an XER lobed cam (226/226 114+2), im pretty sure they are, just double checkin
Old Sep 17, 2004 | 01:02 AM
jrp's Avatar
jrp
SN95 Director
yes, but with dual spring kits costing under 400 dollars (crane, PP, PRC) i'd spend the extra dough. which isnt alot when you factor the cost of the 918's plus tit. retainers.
Old Sep 17, 2004 | 01:05 AM
luv2spd's Avatar
what's the lift? It should work, but you will have to change them more often than if you got duals.
Old Sep 17, 2004 | 01:12 AM
cyphur's Avatar
to the n'th degree. why go cheap on something that can make or break your motor? snap a single spring and see how much a bottom end rebuild can run.......
plus so far i've not seen a patriot dual snap when they're correctly installed.
Old Sep 17, 2004 | 01:18 AM
Ferocity02's Avatar
I use 918's with my XER, no problems.
Old Sep 17, 2004 | 01:36 AM
PREDATOR-Z's Avatar
TR 224 >XE-R ?? are you sure, because I don't think so but I could be wrong
Old Sep 17, 2004 | 10:03 AM
MyLS1Hauls's Avatar
I've got almost 30k on my 918s & XE-R without issues so far. Some are fearful of singles. Will they work...most certainly...should you use duals instead...?
