Darton MID block guys inside......
The answer could be a simple as that.
I'd call Steve@Race and ask him what he thinks. He'd be a great source to ask
Gonna make some calls tomorrow I'll post what I find out
I spotted your question while away on business.
Pull the heads. Make sure both the heads and block are perfectly flat using a machinists straight edge. True up heads or deck if necessary with as smooth a finish as possible. Clean surfaces prior to assembly with a solvent like lacquer thinner or acetone.
Use no sealer on Cometic gaskets. Torque to spec in the proper sequence using ARP lube on studs, under nuts.
Start engine and warm up to operating temperature on a short drive. Let it cool back down preferably over night. In the proper sequence, back off one nut and retorque to spec. Go to the next nut in sequence and do the same. Continue until each nut, bolt is retorqued on both heads. The gaskets will take a set in the aluminum of both block and head. This is why I recommend retorque regardless of what Cometic may say. If it were my engine, I would do this procedure once again in about a month just to be on the safe side. The Cometic MID specific gasket is the only gasket recommended with the MID sleeves for street strip use. Race only engines can use copper gaskets with stainless steel orings in the sleeves.
If your engine (any engine) detonates under nitrous you will probably have the coolant problem regardless. Make certain the mixture is rich enough with timing backed off under nitrous to prevent detonation. Heads will lift under detonation even with racing iron blocks, thick deck heads and high strength half inch bolts.
Ive got probally 2000 miles on my setup and just started dialing the n2o in and ran into a problem. On the bottle it was shooting coolant out the overflow. Did a leakdown test on it and both sides were leaking. Not sure if its a block problem? head gaskets? studs?
Im am using .053 Cometic's that are made for the Darton MID blocks and used permatex adhesive on the gaskets per MTI's instructions. The block is studded and I torqued the studs too 75 foot pounds.
Really curious what others are running and what is holding up. Ive got another set of Cometic's but a little leary of trying them again.
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
hydfixer, thanks for that info!
