Rebuild Questions
and has been dyno'd 4 times and thats about as extreme as it gets. I hate to make another "over 100k" thread but i cant find an outright answer. thanks
and has been dyno'd 4 times and thats about as extreme as it gets. I hate to make another "over 100k" thread but i cant find an outright answer. thanksThe Best V8 Stories One Small Block at Time
Here is a link on how to do a compression check on a LT1 F-body, probably wouldn't differ that much.
http://shbox.com/1/4th_gen_tech2.html#compression_test
Rod bolts - might as well upgrade to ARP while you're there, very easy to do.
Oil Pump - time for replacement
Timing Chain - again, time for replacement
Spark Plugs
If your upgrading the cam you'll want to replace the valve springs/retainers as well. Even if it's not a big cam, 118K is a lot of wear on springs.
As for all your gaskets, TSP sells a two different head/cam swap gasket/bolt kits that have most of them. I used the basic kit which includes: GM head gaskets, GM head bolts, GM water pump gaskets, GM timing cover seal, GM front seal, GM harmonic balancer bolt. But I had to buy my rear main seal, and reuse my rear engine cover gasket (I know, NOT supposed to, but it was in good shape). I also had to buy new header gaskets, but those are cheap. I reused my valve cover gaskets as well.
I have a webshots album of pics from my rebuild, I haven't uploaded the final pics yet, but the majority of them are there. You can see them here: Toonz's Engine Rebuild
Let me know if you have any more questions.
Measure the bearing journals to make sure they're round (and meet manual specs), and inspect carefully, if it passes no reason you can't use as is
