If you throw a rod...
Old Sep 22, 2004 | 03:05 AM
pdd's Avatar
pdd
Originally Posted by kumar75150
Well I called Triple A and had it towed to the shop. I broke down about 10 miles from my house and 5 miles from the shop so had it towed there.
They open at 8AM so I will find out soon enough.
good luck with the fix bro. let us know whats the scoop
Old Sep 22, 2004 | 03:10 AM
goober35's Avatar
Will the motor even turn over. Or was it just stumbling on its face. What shop was it taken to.
Old Sep 22, 2004 | 03:49 AM
kumar75150's Avatar
I actually drove the car about a 1/4 mile from a stop to the gas station staying under 2000rpm. It felt like it was hesitating.
Then I let it idle in at the gas station for about 10 seconds and it was barely idling at around 500rpm.
I took it to Fastech --------------------> sponsor.
Old Sep 22, 2004 | 07:32 AM
Reckless's Avatar
Super Moderator
Doesn't sound like anything drastic Kumar. We'll get it sorted out.
Old Sep 22, 2004 | 08:02 AM
CHRISPY's Avatar
sounds like spring to me
Old Sep 22, 2004 | 10:40 AM
Taspeed's Avatar
i vote broken spring...I threw a rod...errr...3 or 4 actaully, and I've turned bearings before. You would know if you did any of those things. Really sounds like a spring broke or a coil/plug combo isn't firing.
Old Sep 22, 2004 | 10:52 AM
Reboot's Avatar
Another vote for a broken spring.
Old Sep 22, 2004 | 02:26 PM
cyphur's Avatar
since its runnin relatively alright while idle, and you could drive it that 1/4 to the gas station, you most likely didn't do anything so drastic as snap a rod. most likely a spring or two.
Old Sep 22, 2004 | 02:34 PM
Reckless's Avatar
Super Moderator
Broken #5 intake spring and rocker... more info here:
https://ls1tech.com/forums/showthrea...655post1798655
