Rollmaster installed correctly?
Old Sep 23, 2004 | 11:00 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Rollmaster installed correctly?
Green dot - Located just right of the dot on the cam gear
Blue dot - Located just right of the dot on the crank gear
Red dot - Dot on the top edge of crank gear
Yellow dot - Crank key
The Green and Blue dots line up vertically
The Red and Yellow dots lin up
Old Sep 23, 2004 | 11:05 AM
cyphur's Avatar
Hmm good question. I'll be installing the same chain so I've very interested in the answer. This might be a great picture to send to jmx to have put on his site if its indeed installed correctly.
Old Sep 23, 2004 | 11:12 AM
ls1290's Avatar
One thing to add, I believe this should be 'correct' for standard timing( no advance or retard ) according to the fairly lame install instructions.
Old Sep 23, 2004 | 11:31 AM
Damage Inc.'s Avatar
Sweet Cheeks
Assuming that you put the new crank gear on in the exact same location as the stocker, you're looking good. Remember that dot to dot should have cylinders 1 & 6 at top dead center.
Old Sep 23, 2004 | 08:54 PM
P Mack's Avatar
Yep, the way he has the crank gear in the picture is the same as stock.
