TSP Cam with ARE heads?
Old Sep 27, 2004 | 11:26 PM
NassyVette's Avatar
Default TSP Cam with ARE heads?
About a year and a half ago I had an ARE stage 2 heads/cam installed. Anyway I'd like to put in the TSP 231/237 112 cam. Does anyone know if I'll be able to run this cam. My installer says he's pretty sure it would clear since the heads weren't milled much..but that a piston to valve clearence test would need to be done. Anyone of a way to determine this that I can do on my own? Does the new cam need to be in to do it?
Thanks for any help.
Old Sep 27, 2004 | 11:29 PM
NassyVette's Avatar
Here is what ARE's site says about my heads.
Angle Valve Job
Manley Stainless Steel 2.02 / 1.57 Valves
Comp Cams / Manley Double Valve Springs
Titanium Retainers
Full Competition Port and Polish Intake / Exhaust Ports
CC Combustion Chambers
Radius Exhaust Seats
Bronze Guide Liners
Hot Tank and Thoroughly Inspect Cylinder Heads
Viton Valve Seals
Resurface Heads to Desired Compression and Set Combustion Chamber CC
Set all Valve Spring Pressures and Heights
Fully Assembled and Ready to Bolt on
Flow Test with Printout
Used on Bore Sizes 3.90” - 4.00"
Springs Good up to .650” Lift
