GM 2002 ring and coated piston set?
Old Apr 5, 2003 | 09:27 AM
JS's Avatar
JS
Default GM 2002 ring and coated piston set?
I wanted to know if anyone has updated a 99,00,01 motor to the 2002 ring set?I HEARD there better at controlling oil problems and sealing abilities too?
I also needed some info on the 02 COATED pistons as well,Are they worth the upgrade over the 00 stockers even if your 00's look perfect?
JS
Old Apr 5, 2003 | 01:57 PM
Boosted LS1's Avatar
Default Re: GM 2002 ring and coated piston set?
I'd say it comes down to cost. Doesn't the later LS6 have a few more revs? That's not due to the pistons alone but other mods as well. The later stuff will be slightly better but it will cost you. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 9, 2003 | 09:21 AM
Paul F's Avatar
I'll let you know something in the next few weeks. My Vette is going in for the coated pistons and new rings next week. It has way too much piston slap, all the time. I was a little scared to put the blower on that engine and then have it come apart. We'll see how it turns out soon.
Old Apr 9, 2003 | 09:28 AM
Fireball's Avatar
why not look at a good aftermarket file-fit ring set for oem pistons?
Old Apr 9, 2003 | 02:39 PM
JS's Avatar
JS
GM makes a file fit thats better than the 02 OEM.
Guess which one I have on order <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I decided to use my old pistons.
Just need to ball hone the block and number my old rod/main bearings when I put it back together..
JS
Old Apr 9, 2003 | 02:57 PM
Fireball's Avatar
Guess you won't be stock shortblock anymore <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
<small>[ April 09, 2003, 02:59 PM: Message edited by: Fireball ]</small>
Old Apr 9, 2003 | 03:39 PM
JS's Avatar
JS
Brian I've said it many times,once its apart its not stock and in my case its NOT STOCK.
IMO a clean round true bore and a file fit are worth alittle hp,How much I dont know?I'm not balancing the setup though.I will add ARP rod bolts/head bolts too.
See buddy I stick to my own words <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Now I do have one other option but thats not getting talked about unless its a done deal.
JS
Old Apr 9, 2003 | 03:44 PM
Fireball's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS:
<strong> IMO a clean round true bore and a file fit are worth alittle hp,How much I dont know?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Agreed...
But just like you are considering...I hand honed the cylinders just to break the glaze...no honing with a torque plate or anything like that <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
filefits...not so sure...the endgaps are similar to stock specs...if anything my stock rings were looser than my new ones...less friction = more power right...so I Must be losing power with new rings <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
-Brian "still stock pistons, crank and rods" <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Apr 9, 2003 | 04:38 PM
LAST ONE's Avatar
I have seen posts on the GM upgraded ring system to correct oil problems and the result was a motor that made about 10 less hp due to the additional drag and ring configeration but they loosened up after 7or8k and the original oil problems returned,it seems a short term fix.
Old Apr 9, 2003 | 05:23 PM
JS's Avatar
JS
Thats why I'm putting a FILE FIT ring in my car and BALL HONING the block,it wont have any issues after that I hope.
JS
