Best TSP Cam for my application?
Old Oct 7, 2004 | 06:59 AM
PREDATOR-Z's Avatar
Originally Posted by 9833211
What TSP cam will give me the most optimal results? Most cams that are aggressiver have a note saying best for m6 cars. And not recomended for a4s.
A split or reverse split cam with a 112 or lower lsa is harder to tune for A4, unless the tuner knows his stuff of course.
So if you are thinking about a 112, don't be afraid, just pic a no split cam, like the 224R or 225. Stall (3500>4000)
If you plan on lower gears, HI stall (4000+), beefed up tranny and rear then look at the 228R, or 233 torquer.
Think of it this way, fast lobes+less overlap=Power W/good idle
Old Oct 7, 2004 | 07:12 AM
LS1FIRE's Avatar
Thanks for the info. Will there be a power differnce form 112 to 114 lsa? Our just idle?
Old Oct 7, 2004 | 08:11 AM
PREDATOR-Z's Avatar
112lsa will bring the power earlier in the curve and has better low end trq.
114lsa will have less overlap (better idle), power peak will be 200>300 rpm later
Example:
112 cam with power range of 2000>6000 rpm, the same cam on a 114 will have the range from 2200>6200.
To calculate degree of overlap: ([DUR int+DUR exh]/2) - (2* lsa)= degree of overlap.
EXPL: Cam1 > 224/224, .581/.581 112 lsa and Cam 2 > 224/224, .581/.581 114 lsa
Cam 1 degree of overlap ([224+224]/2)-(112*2)= 224-224= 0*
Cam 2 degree of overlap ([224+224]/2)-(114*2)= 224-228= -4*
So the 114 cam has less overlap=idle better, also it will have a better chance to pass emissions, however for every 1 degree more overlap you can expect 2 rwhp so the 112 should (in theory) make ~ (4*2)= 8rwhp extra.
Hope that makes sense.
Old Oct 7, 2004 | 08:38 AM
LS1FIRE's Avatar
Example:
Much thanks for this info. I dont have to worry about emissions. But i am worried about the tune. There is no one that will tune my car localy. Im gona get edit our hp tuners.And then try to find somone that will give me a tune sheet were i could give them my mods and they will send me the stuff i need to type in. I am not sure if this is how it goes. If you have any other suggestions please feel free. And again thanks for the knowledge
Old Oct 7, 2004 | 08:45 AM
silverZ98's Avatar
talk to jason at TSP they sell the cams your talking about and he is the tunner.
and does good mail order tunes
Eddie
Old Oct 7, 2004 | 09:11 AM
LS1FIRE's Avatar
Eddie
Thanks Ed for you reply. I talked with TSP and they only do mail order tunes with Edit. I am not sure to get the hp tuners now. But if i buy the edit i will need to buy a-tap also? Is hp tuners more user freindly? And ive been told hp tuner is like edit and a tap cobined but i am not sure.
Old Oct 7, 2004 | 10:05 AM
luv2spd's Avatar
Yeah, hptuner is like edit and atap combined b/c you can edit and scan with it.
Old Oct 7, 2004 | 10:15 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We tune pcms with ls1edit, but you will be able to open the file with hp tuner if you would like We stock 220/220 sleeper cams & 224/224 camshafts also
Jason
Texas Speed
www.texas-speed.com
806.866.0734
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Oct 7, 2004 | 10:48 AM
LS1FIRE's Avatar
Jason
Texas Speed
www.texas-speed.com
806.866.0734
Thanks allot Jason for your time concerning my matter. Sorry i dont really understand. Does it work like this? You send me a sheet with a tune and then I type it into the hp tuners and thats it? Are the files for ls1 edit and hp tuners interchangable? I did not see any patriot products on your site anymore do you still sell the patriot s2 head and cam package? What kind of dyno numbers are typical with s2 heads and a 225 our 224R cam? Forgive me for my lack of knowledge.
Old Oct 7, 2004 | 11:03 AM
PREDATOR-Z's Avatar
1- TSP does not carry Patriot products anymore. But they carry an alternative with pretty good results so far.
2- No, you will send him your pcm with a complete list of your mods and he will program a tune and send it back to you.
3- With FULL bolt ons, Heads and 224R or 225 cam you should be in the 400>420 rwhp range.
4- If you do not go crazy on the cam (Over 230 duration), there is a new alternative handheld programmer that I've been using (VHP/CRANE). It has 6 base tunes depending on your cam specs, 2 for supercharged and 4 N/A cams.
Read this thread it will give you a pretty good idea.
https://ls1tech.com/forums/pcm-diagnostics-tuning/178427-vinci-handheld-prgrammer.html
I have an XE-R MTI STEALTH II cam 224/220, .581/.581 116+0 and that programmer netted me 404rwhp/383trq with dyno runs + FULL bolt ons, cam only, (stock 241 casting LS1 heads). So for this level of cams it is more user friendly than predator and pretty handy.
Old Oct 7, 2004 | 11:21 AM
LS1FIRE's Avatar
They dont make those programers for 98 yet. How hard is it to remove and wire up the pcm again?
Old Oct 7, 2004 | 12:29 PM
  #32
PREDATOR-Z's Avatar
Real easy! \
Have you talked to Joe V., from what I know they were putting finishing touches for a 98 version.
