Which lifters?
Old Oct 6, 2004 | 02:15 PM
Tech's Avatar
Default Which lifters?
Comp OEM
Crane OEM
Comp R
Other??
Stock heads/cam right now. Will probably do a 23x/23x cam in the next year or so.
Old Oct 6, 2004 | 02:48 PM
Uthinkso's Avatar
I would see no problem with using a new set of the GM lifters.
Old Oct 6, 2004 | 02:49 PM
Cstraub's Avatar
Morels. More money now but for the long haul the best choice.
Chris
Old Oct 6, 2004 | 02:51 PM
Boostaholic's Avatar
I'm running Comp R lifters in my 408 w/ trex and they seem to be fine, although one of them is a little noisy but that was my fault.
Old Oct 6, 2004 | 02:57 PM
technical's Avatar
Unless you need to replace them ie. something broke, the stock lifters are fine.
Old Oct 6, 2004 | 03:00 PM
gojo's Avatar
Originally Posted by Tech
Comp OEM
Crane OEM
Comp R
Other??
The stock lifters are very good and are more forgiving when it comes to preload.
Old Oct 6, 2004 | 05:03 PM
Beast96Z's Avatar
Chris
If you have the money, these are the way to go, but at $500 a set, there alot more expensive than the others. Other than that, stock would work fine for that combo.
Old Oct 6, 2004 | 06:08 PM
MUSTANGEATER's Avatar
Chris
I agree.
Old Oct 6, 2004 | 06:46 PM
Tech's Avatar
GM Parts Direct says $220 for 8
So those are definitely out of the question. I can get my hands on some with 40k in a toasted motor but I'm not real crazy about that idea.
So the new question is... Comp or Crane OEM lifters?
Old Oct 6, 2004 | 10:10 PM
Z06er's Avatar
Check out Ariel Perfomance. They have GM OEM lifters for less than $150 new.
Old Oct 6, 2004 | 10:14 PM
jrp's Avatar
jrp
SN95 Director
comp 850's here. bought them during a TR sale for 179. normal price is still under 200.
Old Oct 7, 2004 | 05:56 AM
Nytmare's Avatar
I have some Comp R's for $150 if you're interested. New in the box and never used. Pm me if interested.
