Valve tap
Old Oct 7, 2004 | 12:10 PM
fastbasser's Avatar
Default Valve tap
Sounds like one cylinder. What wouild you think could cause it. All rockers are torqued correctly. I was thinkin a slightly bent pushrod..
Thanks in advance for your opinions.
Old Oct 7, 2004 | 12:19 PM
technical's Avatar
Bent PR, bad lifter, broken rocker, broken valve stem.
You were in there to check the rocker torque, how about pulling the PR's to see if one's actually bent? Pull the valve covers and take a look around.
