I need the best cam for my setup..opinions please
Old Oct 10, 2004 | 10:40 AM
ccajun4real's Avatar
Originally Posted by Candy
Sweet car! I wouldnt recommend going over a 224 either with that stall. We have our F2 cam 224/224 .586/.586 on a 114 that would work well with your current setup. Let us know if you need anything.
I am leaning toward Futral after hearing the good that all have said. I also like TSP since I have done business there before. I went to the FMS website but can not pull up much info...........says under construction? Is there another link where I can see actual specs and pricing? Thanks
Cajun
Old Oct 11, 2004 | 01:18 AM
badazzhawk's Avatar
try a 230/226 590lift but on a 116...i have done a few of those and without a stall con either....just depends on the tune on the drivability...i love this cam...its a sleeper cam also if you want it to...but still has jus a slight lope if you have strait pipes
Old Oct 11, 2004 | 01:27 AM
LSUxBlake's Avatar
You have to call Futral to get pricing , etc. They open at 9:30 am Central Time, and they'll be glad to talk to you about whatever questions you have. Allan and Candy are two of the nicest people I've ever met.
Old Oct 15, 2004 | 07:27 AM
I went with an MTI C1 cam 222 .570 112 LSA with Isky 295-d springs, Comp PR, and LS6 ported and shimmed oil pump. I think I should be good to go! Thanks to all for the info and help!
Cajun
