Oil pressure and O-Ring question
Old Oct 14, 2004 | 11:16 AM
Cerebrex's Avatar
Default Oil pressure and O-Ring question
My new LS1 with only 5k miles on it was giving me shitty oil pressure, so I went and checked out the o-ring, as I figured it had been damaged. My friend said when he found it, it looked like it might be a little collapsed. He has visually inspected it since, and he says it looks great. My question is, if it looks ok, should it be ok? I mean, it's rounded with no cuts, cracks, or flattened ends.
I am getting 50 psi cold right now, and haven't let it run warm yet. Does this sound like enough? Are there any other thigns I can do to get somemore oil pressure, just for insurance? Thanks for the help!
Old Oct 14, 2004 | 11:23 AM
Boostaholic's Avatar
50psi cold, probably 33-40psi warm @ 900-1000rpm
Old Oct 14, 2004 | 11:24 AM
Cerebrex's Avatar
that's pretty decent for an ls1, right?
Old Oct 14, 2004 | 11:27 AM
luv2spd's Avatar
Yeah, it's not bad. My car is usually about 60 when cold 45 when warm.
Old Oct 14, 2004 | 05:02 PM
Cerebrex's Avatar
hmmm.... what is the oil psi (cold/warm) of a normal LS1??
Old Oct 14, 2004 | 07:21 PM
01_SuperSlow's Avatar
you're good to go at 50 psi cold.
Old Oct 14, 2004 | 09:07 PM
Cerebrex's Avatar
sweet... i'll see what that nets me hot. whats an acceptable hot psi?
Old Oct 14, 2004 | 09:53 PM
WAHUSKER's Avatar
My runs right around 35-40 at idle warmed up.
Old Oct 14, 2004 | 10:06 PM
Cerebrex's Avatar
Is 30 hot too low?
Old Oct 14, 2004 | 10:28 PM
SidewayzOZ's Avatar
Also probably depends alot on what type of oil you are using. Might gain some pressure by changing oils.
Old Oct 15, 2004 | 01:13 AM
30 psi hot is ok, although 40-45 psi is more commonplace.
Old Oct 17, 2004 | 12:43 AM
Cerebrex's Avatar
Commonplace. So how would I get mine more commonplace? I want to be right there in the average.
Old Oct 17, 2004 | 04:10 AM
Originally Posted by cerebrex
Is 30 hot too low?
At what RPM idle? And what kind of oil?
Old Oct 17, 2004 | 04:35 AM
Cerebrex's Avatar
Not sure (car is 450 miles away).... completely warm, at maybe 800 rpm idle (or whatever is normal), with Mobile 1 10W-30. What can I do to increase this number?
