how big can i go..
the deal is i cracked my block a while back and now its time to build it up for real--i already have the heads i want to use (pull off c5r heads) but im still unsure about the block--unfortunitly money is a factor here law school budget --if i re sleeve the stock block say darton or someone what kinda bore am i looking at maximum--what should be the limits i try to pursue here? or would it be better to go iron*grimmace* 6 liter and go from there--i know the weight addition sucks but would it be more cost effective and easier (ie less down time ) to just go that route--i have never considered sleeving the stock bottom before so im clueless as to anything in this area--
any help is appreciated--thx in adavance
also im keeping the stock crank, not that it matters directly but just to get all the info out there that i know for sure thus far--
DJ
To answer your question, you can bore the hell out of darton sleeves. They have 434's running around now IIRC. So at least .060 over. Remember, a 427 is 4" stroke w/a 4.125 bore. That requires a resleeve on a stock block. Can't do but .050-.010 over on a stock block to stay safe(can do more, but most people don't).
and the whole story is that i didnt have to pay bank for the heads, so i have something i can use, but i cannot sell--part of how i got them-and the intake mannifold is taken are of-it's legit--but the old c5r motors cant be popping up for sale in peices or somebody might get an *** full--
moving on i was told the stock crank would not be broken--yes im sure its a heavy heap compared to the lunati ones but i have it now and if it wont break then i figured id use it--if its a weak spot then ill get a different one, thats the point of making this post. plenty of people are making power without huge cubes but i would like to have more than 346--keeping in mind my heads came off a 7 liter it might be good to get the bore size a little bigger--but either way 6L on a budget sounds like the cheaper way i just have to weigh it out and deceide if i should go that way or not
timeto vist some sponsor sites and price some parts--i build my own stuff so i wont be buying someones shortblocks--
anyways im rambling now basically i was seeing if it was pracical to use what i had ie the block and crankk or save for a bit and go with something else--
also the rear and such arent a prob either the sig is very old--
thnaks again guys for the help
DJ
not sure if you need it or not, but its come in handy for me from time to time. i understand the situation about the C5R heads...but yea, I would still try and save up to do it right the first time around instead of half-assing it and getting poor results, and just redoing it 6mos down the road. JMO.
