ls1-396
Old Oct 16, 2004 | 08:28 AM
1970judge's Avatar
Default ls1-396
i have a 98 firebird with a 3.8 v6 but i am soon swaping for a ls1..what does it take to get the ls1 taken out to a 396?? and can yall give me advice as to what to watch for as far as part i will need to replace to make the ls1 work right in my car.
Old Oct 16, 2004 | 08:42 AM
abate1224's Avatar
i have a lunati 395cid stroker in my car. check out several of the sponsors. most carry the kit.
Old Oct 16, 2004 | 09:16 AM
1970judge's Avatar
hey dude i live in ft worth now but i used to live in groves abotu 20 min out of beaumont..you visit groves any??...cuz i go back regularly to visit teh family
Old Oct 16, 2004 | 09:47 PM
John_D.'s Avatar
For the swap... LS1 k-member, LS1 steering rack, LS1 lid. If the engine doesn't come with alternator, starter, maf, etc, then round up all that stuff too, including brackets. Upgrade the radiator (I did a SLP radiator). LS1 tranny and crossmember and exhaust hanger bracket. You'll have to feed power to the INJ2 circuit on the pcm.
V8 springs, shocks, swaybar for the front. (rear springs and shocks are the same, but the rear sway bar is smaller, so probably upgrade that). A 97 vette fuel rail to tie into the return-type fuel system, or convert the tank and lines to the returnless style used on the LS1 f-bodies. LSD rear would be very useful, if you don't have it already. 1 piece driveshaft, if you don't have it already. V8 exhaust. V8 radiator hose, heater hoses (the fittings are different) - or dremel off the ends and just put regular heater hose and clamps on it... V8 gauge cluster (so the tach will be right, and the speedo will read higher too).
Old Oct 16, 2004 | 10:38 PM
jrp's Avatar
jrp
SN95 Director
sell and pick up a cheap 98 or 99.
for 395ci its comes out to a 3.905 bore and 4.125 stroke.
Old Oct 17, 2004 | 08:50 AM
abate1224's Avatar
my wife is from groves. we go there quite oftern. i am the store manager at circuit city in beaumont. if you are ever in town come by the store i am usually there.
Old Oct 17, 2004 | 10:46 PM
ROCNDAV's Avatar
Have you checked out Magnus' site?
http://www.dxsoftware.com/magnus/
I'm currently working on a similar 1994 3.4 to 395. Your conversion will be much easier than mine, but still a bitch
D
