Shimming the oil pump
Old Oct 22, 2004 | 06:14 PM
Cerebrex's Avatar
Default Shimming the oil pump
How much PSI would shimming the oil pump net you? I'm talking about normal shimming (.100-.110). Thanks for the help!
Old Oct 22, 2004 | 06:42 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
10-20 psi over what you have right now.
Old Oct 22, 2004 | 06:49 PM
Cerebrex's Avatar
i have about 45psi cold now, so that wouldnt be too much would it?
Old Oct 22, 2004 | 10:29 PM
jerflash's Avatar
hey you mean that when you get a double roller and you used those shims on the pump you get more oil pressure?
or are you talking about something else?
Old Oct 22, 2004 | 11:25 PM
P Mack's Avatar
He's talking about shimming the spring inside the oil pump to build more pressure. Would that give more pressure at idle too, or just at higher revs?
Old Oct 23, 2004 | 12:30 AM
Cerebrex's Avatar
I hear it gives more pressure all around, but I'm wondering just how much? I've heard 7 (with port), 10 (w/o), 20 (w/o)... lots of inconsistency.
