my 04 gto has some sort of sludge in the engine
Old Oct 24, 2004 | 10:38 AM
the judge's Avatar
Default my 04 gto has some sort of sludge in the engine
i have an 04 gto with a hc package. two weeks ago i started it in the morning and the lifters would not pump up until 3 minutes later after the motor got to temp. so i figured my high spring pressure colapsed the lifters so i decided to pull the heads and replaced the lifters. when i pulled out the lifters i opened one up an found a black tar like substance inside next i pulled the oil filter and had same stuff inside. does any one know if a leaking head gasket would cause this because every couple weeks i have been adding coolant? my car has 7000 miles on it and i change oil 3000 mobile 1
Old Oct 24, 2004 | 10:49 AM
Another_User's Avatar
Coolant should make your oil look whitish, foamy, or otherwise simliarly nasty. If anything is happening, blowby is getting into your crankcase. But that is just my opinion.
Old Oct 24, 2004 | 11:02 AM
the judge's Avatar
its almost impossible to see dexcool in your oil because it blends in so well i poured fresh mobile 1 in a jar with some dexcool it almost untraceable
Old Oct 24, 2004 | 07:38 PM
silverbullet00's Avatar
It will turn your oil like a whiteish gray color and is a head gasket that is leaking
Old Oct 24, 2004 | 07:48 PM
ls1fbod's Avatar
doesn't have a warranty?
Old Oct 24, 2004 | 08:04 PM
Heh. I doubt it has one anymore. I can't think of a dealer that would be nice enough to warranty a vehicle after a H/C install. Thats a shame.
