What kind of power would this setup make....
Old Oct 29, 2004 | 06:39 AM
SPANKY LS1's Avatar
Default What kind of power would this setup make....
~11.0 to 1 compression ratio iron block 408, AS S3 6.0 heads, flow ~330 @ .600. 245/250 .570 .570 114 cam, LSx 90mm intake, 90mm TB, 1 3/4 to 1 7/8 stepped headers, dual cutout y-pipe, full boltons, M6 car? Where will this setup peak at?
Since the cam is only .570 lift, should I use higher ratio rockers to achieve more lift, or is .570 sufficient? I would also like to spray 150-200 wet on top of it if need be How much power am I leaving on the table with .570 lift, versus .587 or .604? (See below) Enough to warrant a rocker arm upgrade?
Lift with 1.70 rockers: .570
Lift with 1.75 rockers: .587
Lift with 1.80 rockers: .604
Thanks, Shawn
Old Oct 29, 2004 | 03:56 PM
SPANKY LS1's Avatar
No thoughts or opinions?
