Need a cam with more lope??
Old Nov 3, 2004 | 06:56 PM
ldickson's Avatar
Default Need a cam with more lope??
I need some help finding a cam with more lope and not haveing to retune the car. I have the 224/224 114 now.Have any of you guys done this?
Old Nov 3, 2004 | 07:09 PM
Beast96Z's Avatar
Any time you mess with the cam it is always best to re-tune. If you like the power your cam has now, consider spliting the duration to a 224/228 and drop the LSA to a 112. The lower the LSA you go, 112,110,108, etc... The more lope you will get. The lower the LSA also means less driveability in most cases.
Old Nov 3, 2004 | 09:21 PM
mcflyz28's Avatar
lower your idle speed
Old Nov 4, 2004 | 12:13 AM
Tranzor's Avatar
Yep... if you're idling around 800-850, try dropping the idle to 650-700 and see if you like that.
Otherwise if you want a cam with more lope, get something around the 230+ range for duration with a 112 lsa.
Old Nov 4, 2004 | 12:26 AM
Ferocity02's Avatar
A 224/224 112 will give more lope w/o needing much tuning. Also don't lower your idle too much, I have heard it will eat gas if it's too low. Mine is about 700-750 right now.
