offset ground crank motor build up questions....
one of the things i read, was an offset ground crank to 3.82
Click here for the topic
no change in strength from stock, maybe a bit more strength? if that is true, would that hold up to say a 200 shot of nitrous? i'd probably only really do 100shot, but just for the sake of knowledge.
also, i was looking at putting that crank in let's say a .030 over 6.0L block. so with that 4.030 bore, and a 3.82 stroke, i get a engine size of around 390cid. Now is there anything wrong with that combination? i see topics of rod/stroke ratio and sideloading the cylinder walls and other stuff like that. anyone see anything wrong with this combo? i'm new to this whole LS1 engine building experience so i'm sorry if I may not be phrasing the questions properly. thanks!
Chris
<small>[ April 10, 2003, 07:11 AM: Message edited by: z28kid98 ]</small>
Goodluck! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
What size rod would someone recommend for something like this? I don't have a crap load of money for a set of wild heads and cam, so some outrageous set of rods to handle a lot of power isn't necessary.
Also, would it be better to mill the 6.0L heads down, and get pistons that match up to what i want my CR to be, or wouldit be better to leave it the way it is, and then just get pistons to match THAT combustion chamber size to get my CR?
Chris
<small>[ April 10, 2003, 05:35 PM: Message edited by: z28kid98 ]</small>
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
also, I'd cut the heads, Diamond has off the shelf 4.030 pistons.
<small>[ April 10, 2003, 12:55 PM: Message edited by: Ryan ]</small>
