GM or Cometic Head Gasket
Old Nov 26, 2004 | 05:49 AM
FireHawk22's Avatar
i gust order my cometic .74 thick to lower my CR because i am using the sts turbo.but what i need to know is do i have to make O-ring on the block or the heads if i am using this Gasket.
thanks for help,
Old Nov 26, 2004 | 05:07 PM
2001CamaroGuy's Avatar
thanks for help,
is it an O-ring gasket? if so then yes you have to O-ring the block and head....if not then no....
now every gasket I have ordered from Cometic has been a non O-ring gasket (the Darton sleeve MIL gasket isn't an O-ring....I know that much)...
Old Nov 26, 2004 | 07:10 PM
FireHawk22's Avatar
what about if i didnt make o-ring in tne blouc or the heads what could hapend.
thanks,
Old Nov 26, 2004 | 07:57 PM
thanks,
the head will not clamp down right on the block.....
at min, you will have WAY more than "0.074" gasket"
worst case the gasket will not seal at all.....
Old Nov 26, 2004 | 10:46 PM
LASTLS1's Avatar
6 Second Club Moderator
I just ordered the MIL darton gasket from cometic. I was using regular cometic gaskets, I got a little water in the cylinder. I hope this solves the problem. I never knew there was a special gasket to use for the dartons!
Old Nov 26, 2004 | 10:52 PM
strokedls1's Avatar
Never heard of an oringed head gasket. If you wanted to ring it you just machine the head or the block and add some wire. Most people don't oring these blocks and they don't have problems on high boost turbo set ups. You will be fine with just the gasket. How come you didn't just flycut the pistons and keep the quench tighter. With that thick of a gasket you are going to be more prone to detonation.
Old Nov 26, 2004 | 11:34 PM
I almost made that mistake......when I ordered my new gasket I didn't think to tell the guy I was putting the gasket on a Darton block......good thing he thought to ask "hey, what kind of block do you have?"
Old Nov 27, 2004 | 09:30 AM
FireHawk22's Avatar
then i have to make the o-ring .
Old Nov 27, 2004 | 03:20 PM
strokedls1's Avatar
You can use some copper wire to make the oring if you have done the head machining to make it work. It is not necessary though. Just use your cometics and forget about the orings.
Old Nov 28, 2004 | 02:58 AM
FireHawk22's Avatar
ok this week i am going to instaal my cometic gasket and the sts turbo.
thanks all,
