Who's running SBC rods in an LS1?
So I call Lenginfelter and they say the same thing about the rods offset, and that they would fit, but that is not how they were designed by GM so they would not run a sbc rod in an LS1.
Anyone running SBC rods in an LS1 with huge power, I will be making 1000 hp. Otherwise I will just buy a new set of Crower or Oliver billets for an LS1.
No, the SBC rod is offset to one side by about .040 since the SBC bore is not centered over the journal like the LS1 is. You can spot face the one side of the rod and get it centered if you run into an issue, or you can buy the right rods for a LS1.
The big thing is to make sure it isn't in a bind when you assemble it...
