408 hp questions
Old Nov 12, 2004 | 01:55 AM
Orange Crush 408's Avatar
Default 408 hp questions
408 callies crank Je rods, 10.5-1 wiseco pistons, 244/225 .638 lift 110 lobe separation lunati cam, patriot stage 2 4.8/5.3 heads, and LS-6 intake. What am I doing wrong? guys in the dyno section are expecting 550rwhp. how? What can I do to get there n/a. Please Help. Need your feedback. SORRY. cam is a244/255
Old Nov 12, 2004 | 03:13 AM
PREDATOR-Z's Avatar
Limited info but off the bat, I would say more compression needed, stage 3 heads and if that cam is a reverse 244/225, way too much split (unless these are durations at different lifts).
But Give us detailed mod list and dyno graph.
Old Nov 12, 2004 | 04:05 AM
cyphur's Avatar
yea thats a pretty wicked split man. dunno why you'd have it that big. 244/236 would be a more desireable split if you MUST have a decent reverse split for your goals. i'd also get the heads reworked to up the compression a little. and make sure your tune is dead on.
Old Nov 12, 2004 | 05:22 AM
SPANKY LS1's Avatar
Oddball cam (as stated above), might wanna try a 244/248 114 or similar. And you don't have enough head IMO. You need a more than a S2 5.3 head for a 408.
Shawn
Old Nov 12, 2004 | 07:24 AM
Brian Tooley Racing's Avatar
Originally Posted by TAQuickness
What he said
We have not seen a Stg 2 head break 450 RWHP on a big engine, we even had one of the most respected names in the business Stg 2 head on a 408 make 430 RWHP.
Our Stg 3 6.0L heads just made 525 RWHP on our very conservative dyno.
Old Nov 14, 2004 | 11:36 AM
bump..
Old Nov 14, 2004 | 11:40 AM
O2bqwik's Avatar
the people expecting 550rwhp thats with 90mm intake, 17/8 headers,stg 3 heads, a good size came. your problems is that weird *** cam, the small heads
Old Nov 14, 2004 | 11:45 AM
necrocannibal's Avatar
Hey I think that was my car!!!
Anyway I found out that day at TEA that heads are VERY important in making big power on bigger motors. My heads flowed 296 @ .600 and need to flow atleast 325. I am buying some TEA Stage 3 heads around christmas, hopefully their move isnt going to slow down the process of getting them out.
Old Nov 15, 2004 | 07:21 AM
cyclerage's Avatar
In a 408cid, I would be running a cam something like 248/252 or larger depending on how the heads flow in and out.
Old Nov 15, 2004 | 10:52 AM
H82BBad's Avatar
Well Dustin Butt's made 500+ rwhp with a 402 with a 236 cam so it can be done with smaller cams provided all the important things are there.
He had TEA stage 3 6.0l heads, lsx90, 1 7/8 kooks etc. He is in the process of changing to the soon to famous "Fireman" cam. so it will be interesting to see what it makes.
Old Nov 15, 2004 | 11:01 AM
Yeah I am buying Stage 3 6.0l heads and bigger cam around christmas. I know they are both too small. I just didnt have the cash to do it all when it was built.
Old Nov 15, 2004 | 01:54 PM
JZ'sTA's Avatar
Also you never told us if you were a A4 or M6 car.
That will also make a huge difference.
You cam is large and much better then what you first posted.
I Defentially agree you just aren't geting enough air into the motor.
Swap to stage 3 6.0 heads milled 50 thousands for compression and add a 90mm setup and you should see a huge increase in power.
Old Nov 15, 2004 | 05:43 PM
383ss's Avatar
that's funny, my stage II heads with 2.02/1.60 valves and 'only' flow 293 @ 600 and I dyno'd 542/535 with NO tuning and a 246/250 cam, in a 408
1 3/4 dynatechs too.
Old Nov 15, 2004 | 06:07 PM
My cam is ALOT smaller than yours as well. That is one of the things I am changing when I do heads. What compression are you running?? Mine is only slightly higher at 11 to 1.
**EDIT**
Nevermind just saw 12.5 to 1. Thats ALOT higher than mine too. Is this a streetable car?? Mine is a daily driver and if that much compression is streetable when I get my heads I will up the compression some. And I do mean pump gas, no race fuel.
Old Nov 15, 2004 | 06:58 PM
383ss's Avatar
nope, mine is a race car. cam is not outrageous on mine though. it was specd for at race motor 383.
you said your cam was a 244/255?? that is about the SAME size as mine.
wasn't trying to insult your numbers, just saying that mine is a small head car and my head flow peak numbers are NOT impressive. those things aren't the end all to power.
Old Nov 15, 2004 | 07:03 PM
No my cam is 234/242 .598/.610 114+4. Its not that big for my size of motor. My car is also my daily driver. I really wished I had a second car to drive so I could go a little more radical with it.
Old Nov 15, 2004 | 07:46 PM
C4VetteLS1's Avatar
Ive got a TEA Stg 2 headed 408" in my car now..ill post its #'s after final tuning and some more street breakin mileage... What heads are you running on yours? Ive got a 238/248 XE-R @ 112 cam in mine......
Old Nov 16, 2004 | 04:51 PM
Dustin Butts's Avatar
Haaaahaaaa..."Fireman" cam....you chucklehead. I just hope I can top the 525hp number Brian quoted earlier. I will say this....she's is pullin WAY harder up top now. I should have her dynoed and final tuned tomorrow.
Old Nov 16, 2004 | 06:38 PM
383ss's Avatar
they are a non-sponsor, so I didn't post them. I'll pm you if you want.
