Ordered a Comp Cam...have questions about ICL
<small>[ April 14, 2003, 12:13 AM: Message edited by: ChiTownSS ]</small>
<strong> Yeah, I was pretty nervous/upset about the fact that I don't have any advance in my cam. But I was going to buy an adjustable/heavy - duty timing chain anyway, so I'll just put some advance in it. What timing chain should I go with? I need one that will work well, without any issues, with ASP pullies. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would recommend 4 degrees (6 might be better)of advance in your cam. Even if it peaks slightly lower than you like it will 60' and et better with the torque coming on lower.
I have a Rollmaster double roller chain in my engine. Works great. I have a Comp 218/218 with a ICL of 114 and 6 degrees of advance. My peak hp is 6000 however no significant fall even at 6600 rpm.
You really need a dyno to know for sure where you are.
ASP pulleys has nothing to do with what timing chain you buy.
<strong> Oh, sorry about that Jason. So I don't need to advance my cam then? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Doesn't the Thunder 227/224 have some advance ground into it? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, 2 degrees advance.
4 degrees????
6 degrees????
Thanks for all the help guys. Again, I do not wish to spin my motor past 6,500 rpms - But it would be nice to have the extra power there if it is needed.
Jason
<small>[ April 15, 2003, 06:55 PM: Message edited by: ChiTownSS ]</small>
