Changing from 5.7 to 6.0
Old Nov 12, 2004 | 08:11 AM
LS1 BU's Avatar
Default Changing from 5.7 to 6.0
I have a engine knock. I'm thinking about swaping to a 6.0 liter motor. What would I have to change for the swap?? I heard I have to drill and tap a hole to mount the altenator. Are the motor mounts and oil pans interchangable. I would upgrade the rod bolts/reuse my ported oil pump.
I'm thinking of reusing my TEA stage two 5.3 liter heads and my F13 cam. They have 2.02/1.57 valves. Would I have to open up the chambers for the bigger bore.
Or a TREX cam with the stock 6.0 heads.
What do you guys think??
Old Nov 12, 2004 | 12:54 PM
LS1 BU's Avatar
No one has an opinion??
Old Nov 12, 2004 | 01:11 PM
777's Avatar
777
I'm pretty sure the 6.0l is a direct swap besides the alternator...personally i'd go with the 6.0l heads and the fm13 cam...
Old Nov 12, 2004 | 01:28 PM
LS1 BU's Avatar
I'm gonna run the stock 6.0 heads with a trex or juggernaut cam.
