Cam and 1.8 rockers
. `Remember, rocker-arm ratio changes the clearance, and advancing the cam reduces the intake clearance and increases the exhaust clearance. Milling the heads reduces piston-to-valve clearance, and larger valves usually require bigger valve pockets in the pistons`
the changes excpected after switching to 1.8 :
lift increaces by 10% and accelerates the valves more quickly during opening and closing . by increasing the rocker arm ratio, u get the benefits of higher lift cam without the tuning headaches that often accompany installation of a bigger stick.
wahhab
