heads and cam or ATI procharger
Really? Check your math again. Here's what I have spent for my H/C setup:
TSP 224R Cam - $340
LS6 Stage-II P/P Heads - $1250 (complete w/ valves, springs, etc.)
LS6 Core Heads - $350 (bought for $750, then sold off valves, springs, rockers.... net cost $350)
Grand Total = $1940. Granted, this does not include gaskets or tuning, but when its all completed - including tuning - the "Grand Total" will be less than $2600, including install. Much less than your estimated $4.5k - provided you can do the install yourself. Although, an install should only run ~$750 give-or-take, anyways.
Perhaps that may help sway your choice. F/I for $5k, or the same power for half the cost with a H/C setup. Easy choice for me.
The drivability was affected very little unlike a head/cam package that makes approx. the same power. It does not require constant maintenance, if you want more power in the future all it will cost is a pulley and another dyno tune. anytime you add power to a motor you add stress no matter how its done. the Procharger kit can be done in far less time and labor than a head/cam swap.
I have owned several head/cam cars in the past but since going supercharged
im hooked.
im hooked.
Supercharging does attract less attention. Im thinking of guetting a C5 Vette and will definately FI it (Once the Z goes race only).
Remember though, forced induction can be very costly. Built motor to handle boost, turbo/blower kit, fuel/tune (something that is not as expensive H/C wise) are some of the things that I didn't see the big picture in when I went with F/I.
Andy
