rocker arm preload
0 lash THEN 22 LBS/FT trq with a really good torque wrench.
FGS how hard is this to understand."
Many of you are confusing "PRELOAD" with "THE ROCKER BOLT TORQUE SPEC"...So, me try to explain this simpler...
Stock LS1 rockers are not adjustable...The rocker pivot sits down flush in the rocker rail seat...You tighten the rocker bolt to 22ft.lbs. so that it does not come loose...
The rocker is totally down, as far as it will go...Even if you tighten the rocker bolt to 50ft.lbs., there will be no additional pressure added to the lifter...
This is the reason that if you need to physically change the amount of preload on a stock LS1 style valvetrain, you must change the length of the pushrod, or shim the rocker rail...
Now, with the adjustable rockers...There is no TORQUE DOWN spec for the rockers...And this is because the rockers DO NOT SIT DOWN ON ANYTHING...Preload from the lifters is all that keeps them in contact with the upper adjusting bolt...
I just finished installing the CraneCams Gold Race Adjustables on my Z06 at about 5 p.m. today...The install procedures were as follows...Hand tighten the rocker adjusting bolt until ZERO lash (no lifter compression and no spring tension)...Rotate the engine 1 full revolution and tighten any loose bolts...Repeat for a second revolution...
This determines the base starting point...Then is increments of 1/4 turn on each adjusting bolt, begin tightening all rockers down...Wait 15 minutes between each incremental adjustment...Do this a total of 8 times...
Now, what did that mean in actual inches of preload...
ZERO LASH...Measured 0.320"~0.330" from the top of the adjusting bolts down to the pivot bolts on all 16 rockers...
After final 8th 1/4 turn or 2 full turns...The same measurement now checked 0.230"~0.240"...
So, basically CraneCams is specifying 0.090"~0.100" of preload height...
Hope this helps...
BY THE WAY...THIS SWAP DID IN FACT ELIMINATE MY TAPPING...THE VALVETRAIN IS NOW VERY SWEET SOUNDING AND NO TAPPING...
As for you guys that are saying less preload has been making more power...I read a good thread on this last week, which sealed my decision to go with the adj. rockers...
Basically, what it said was this...With the all ALUMINUM LS1 engines...If you do not have enough lifter preload, i.e. 0.04" or less...As the engine and heads get hot and GROW...You loose that preload, effectively giving you less and less as the engine gets warmer and warmer...
In my case, when I first started my car in the morning...IT WAS PERFECTLY QUITE...Then as it warmed up, the tapping would get louder and louder...At first, I thought it was lifters going down/failing...Then I read this thread and it made alot more sense...So, I went with the rocker swap...
One other point I would like to clarify...Gollum...The ProGold rockers did not appear to be any heavier than the stock rockers...And the mounting bolt and adjusting bolt do not move with the rocker, so they add nothing to the "effective" valvetrain weight...
Peace...Gman
PredetorZ. You are just not understanding things. I have a custom ground cam and apperently I needed a different length pushrod. Yes you torque the rockers to 22lbs and go IF you have the right valvetrain preload. If I were to keep the 7.4's I would be hanging valves open, so I had to go with a shorter pushrod.
Thanks for the replies guys... I think I am set now
You guys are talking about rocker bolt turns on a non adjustable stock rocker.
What does this have to do with preload???
Whether you shim or change p-rod size, with NON adjustables the bolt tightening is still the same 22lbs/ft.
Now which part didn't I understand ??
So you will most definitely have "less" lifter preload when using the aftermarket cam with stock length pushrods and OEM rocker arms torqued to specs.
I have seen people needing longer pushrods when going to a higher lift camshaft to get the correct preload.
Now the LS6 cam is even smaller than that, that is why 7.45 p-rods are recommended for LS6 cam applications in a LS1 stock headed car.
Some poeple will tell you they ran stock p-rods with an LS6 cam and "no problem", but they are usually noisier as they rely on their lifters to compensate on pump up.
Vortech, the ford rockers are the same. Even when you have non-adjustable rockers there is still a preload on the lifters, but you have to adjust it with pushrods only just like the LS1 when using non-adjustable rockers. This doesn't mean pushrod length is negotiable when using adjustable rockers. You always need to use the correct length pushrods.
Most all aftermarket cams have the nose of the cam .005" below the height of the cam journal. This is so the cam can be installed throught the journals. It also is that way so the lobe can be as big as possible which is favorable to lobe dynamics. Since the nose is the same height and location on all cams, that means as the lift increases the basecircle decreases. If you measure your stock cam across the basecircle and then measure your performance cam across the base circle, you will find the performance cam indeed has a smaller measurement. Now if you take half the difference between the two basecircle measurements, you will have exactly how much longer your pushrod must be to have OE preload! It's called geometry!!!!
Now if you have screwed up the valve tip height by not measuring it before a valve job (so you would know how much to grind the tip back to OE height); or if you have milled your heads, the easiest way to accomplish proper preload is to buy a set of adjustable rockers. I happen to like my Cranes because they are extremely quiet; they have the accelerated lift geometry that really does provide a noticeable power increase, and they are adjustable!!
FWIW, in the old days you would adjust the rockers while the engine was running. Loosen then tighten until the tapping was gone.
The ideal preload for stock LS1 lifters is .060. They are forgiving and .040 to .090 will work. I like .060 and not much either way. If Cranes can stand a lot more, my guess is they have rapid bleed down.
