Harlan Sharp preload 2 turn w/o shims?
Am I wrong with out the shims? For full write-up see http://www.ls1howto.com/index.php?ar...5404a4acd7a09e
"If you get MORE than 1 full 360 degree turn on each bolt, remove the rockers and install the shims on the bottom of the pedestals and repeat this process to check the new preload. The shims seem to reduce the turns by approximately 270 degrees. You must install a shim on BOTH bolts, not just one or the other. If you got LESS than 1 full 360 degree turn then you are ok to leave the shims out!"
The car is a weekend ride, I will check this next weekend by just breaking the rocker bolt loose and seeing if the spring unloads any. That would tell me if there is truth to this shim thing beyond 1.5 turns.
Very nice website.... JmX is DA MAN !
I WILL NOW SEE IF THE SPRING UNLOADS WHEN I LOOSEN THE ROCKER, I WANT TO HANGE CAMS NOW. IT WILL REQUIRE NEW SPRINGS, SHIMMING WILL BE DONE AT THAT POINT IF NEEDED. I NEED STOCK IDLE SO I WAS THINKING OF A SIMPLE LS6 CAM. PRICE IS GOOD TOO. THE LIFT WITH THE 1.8'S WIL BE ABOT .580" SO I'LL NEED SPRINGS AND I WILL NEED THE LONGER PR'S.
