can anyone confirm stock cam VE?
Old Nov 24, 2004 | 09:20 AM
cablebandit's Avatar
Default can anyone confirm stock cam VE?
here is what i found for 97 ls1 stock cam valve events. Does anyone know if these are correct?
intake opens @ .50 -12 BTDC
closes 34 ABDC
113 centerline with .473 lift
exhaust opens @ .50 46 BBDC
closes -16 ATDC
121 centerline with .478 lift
202/210 duration with 117 lsa
This is very important to me...thanks
Old Nov 24, 2004 | 10:09 PM
wow...you'd think thats the one cam everyone would now...the first
Old Nov 25, 2004 | 06:23 AM
Sport Side's Avatar
202/210 117lsa 121icl
Is that correct?
@.05
IO= -20
IC= 42
EO= 38
EC= -8
ECL= 113
Overlap= -28
Old Nov 25, 2004 | 07:23 PM
where did you get those specs?
Old Nov 25, 2004 | 08:04 PM
Sport Side's Avatar
Which? The valve events?
I took the specs of the camshaft you gave, and then got those valve events.
Old Nov 25, 2004 | 08:33 PM
gojo's Avatar
Intake Duration - ID 202
Exhaust Duration - ED 210
Lobe Center Angle - LCA (also known as LSA) 117
Intake Centerline - ICL 113
Intake Valve opens - IVO 2 BTDC (- indicates ATDC)
Intake Valve closes - IVC 20 ABDC
Exhaust Valve Opens - EVO 46 BBDC
Exhaust Valve Closes - EVC -16 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 121
Overlap....................... -28 degrees
Old Nov 26, 2004 | 05:48 AM
i dunno any of the specs, that's what i am trying to find out. The ones i listed were some i came across on the 'net
