Shaft Mounted Rockers
Old Nov 28, 2004 | 07:23 AM
wrlowry's Avatar
Default Shaft Mounted Rockers
Has anyone used the Comp Cams 5054170 or 5154180 Shaft mounted Rockers? Just woundering if I will have Problem with them.
1999 LS1 comp cam 528/535-218/224 114 at .050 981 springs 7.400 Push rods
will they fit under the covers and are they avalible yet.
Old Nov 28, 2004 | 09:06 AM
PREDATOR-Z's Avatar
Overkill, don't even bother.
Old Nov 28, 2004 | 02:14 PM
BTL FED's Avatar
Ya some say overkill, but I would always rather have overkill than just enough, its only money right I dont have any experiance with the comps but I have set up a couple of the Jesel Adjustable rocker and they are a VERY nice piece. I like having the ability of setting the preload I need per lifter instead of having to shim the entire rail, and try and get as close as possible.
Old Nov 28, 2004 | 03:43 PM
redrocketls1's Avatar
ls1speed and thunder says either the patriot or cc shaft mounted rockers will clear fine
Old Nov 29, 2004 | 10:57 AM
Unaffliated Racing's Avatar
I'll let ya'll in on a little secret. There is no shaft rocker that is a bolt on install.They are not made to be. None of them will clear a stock valve cover.(modified stock cover, yes) All will require a short pushrod like 7.050" or 7.100" and all will require the heads to be modified by elongating the pushrod hole.
